IT "consultant" in Stockport area?
Discussion in 'Desktop & Laptop Computers Forum' started by Keiron, Jan 9, 2012.
  1. Keiron
    Keiron
    Feb 22, 2001
    3,321
    Stockport
    +112
    I have spent way too much time (and money) over the last couple of weeks trying to get my Synology NAS working properly. I get slow transfers (possibly due to my PC rather than the NAS) and I cannot configure it to allow access over the internet.
    I have tried the online help for Synology and they are useless. The forums there are poor too. People here have been extremely patient but alas, it still doesn't work properly.
    I'm now prepared to pay someone to come and have a go.
    Does anyone know anyone around the Stockport area? Also any idea how much I should be paying? My guess is it shouldn't take more than 90 mins - if they can't work it out in the first half hour, they never are going to.
  2. marshallp
    marshallp
    Dec 29, 2003
    205
    Manchester
    +24
    What sort of transfer speeds are you experiencing?
    Also, why don't you use something like DropBox to store files online rather than opening ports on your home network?
  3. Keiron
    Keiron
    Feb 22, 2001
    3,321
    Stockport
    +112
    About 10MBps (was hoping for at least 4 x that)
    A NAS is a different beast entirely!
  4. marshallp
    marshallp
    Dec 29, 2003
    205
    Manchester
    +24
    I need a little more information about your setup.
    I assume the SYNOLOGY is connected via CAT5, into what?
    Are you transferring files over WiFi or CAT5?
    What type of files are you transfering?
    Accessing a NAS drive over the internet isn't all its cracked up to be unless you have an outstanding internet connection. If your planning to move large files or access multimedia content think again, it will be very frustrating!!
  5. Keiron
    Keiron
    Feb 22, 2001
    3,321
    Stockport
    +112
    Thanks. I do have a couple of (long!) threads running and wouldn't wish to start a new one here but any tips are gratefully received!
    slow transfers
    http://www.avforums.com/forums/networking-nas/1566173-slow-transfer-speeds-synology-nas.html
    remote access
    http://www.avforums.com/forums/networking-nas/1569153-open-port-tp-link-td-w8960n-router.html
    Cat 6 in fact. Have tried through a gigabit switch and directly from PC to NAS
    Cat6
    Everything from small documents to 35GB blu ray ISO rips
    The main reason for remote access is so I can view and listen to my media files on iPad, iPhone etc. The Synology apps for browsing and replaying are very good - if only I could get them to work outside of my house (ie I can get them working on Wifi - is that the LAN? - but not over the internet or 3G - the WAN?)
  6. Keiron
    Keiron
    Feb 22, 2001
    3,321
    Stockport
    +112
    Anyone know anyone, please? I have a very expensive paperweight in urgent need of attention.
  7. dannycorker
    dannycorker
    Jan 11, 2009
    156
    +19
    The ethernet port on the PC definitely gigabit not just 100? That was the problem I had that resulted in me only getting 10MB/s. I live near you, but unfortunately couldn't really recccomend anyone professional.
  8. Keiron
    Keiron
    Feb 22, 2001
    3,321
    Stockport
    +112
    Thanks dannycorker, yes it's gigabit. I'm reckoning I've spen tthe best part of 100 hours trying to set up my NAS. I take one step forward, 2 back and I have now officially given up on trying to do it myself.
    If anyone knows anyone - or indeed any support I can get that will take over my PC remotely to fix my problems - please let me know.
  9. bryanchicken
    bryanchicken
    Aug 1, 2007
    1,301
    63
    +155
    are you able to try different cables? I had a PC that only connected at 10Mbps and it turns out its because some of the cores in the network cable weren't terminated properly.
    If i understand it correctly gigabit speed needs more pairs of cores than 10 or 100.
    Does the NAS say anywhere what link speed its got? There must be a way to find out. On linux i use 'ethtool' but i don't know whether it will be available for your NAS. Maybe the UI says?
  10. rampant
    rampant
    Apr 24, 2006
    2,254
    116
    Sarf est near londoninium
    +885
    on your network card have you turned off auto detect and selected 100/full duplex as the connection type?
    also is your switch / hub manageable and can you do the same there?
    auto detect negotiates each packet with yuur hub - this is the biggest slow down ever
  11. rampant
    rampant
    Apr 24, 2006
    2,254
    116
    +885
    or if your hub supports it select 1000/full duplex
