loz_the_guru
Hi ALl,
I bought a Boxee box for streaming uses, and i'm having some odd issues connecting it to my TV. I've tried a variety of scenarios, so i'll explain what's going on below.
Boxee to TV with cable 1 - splash screen shows, after that the screen flashes to blue and stays there
Boxee to TV with cable 2 - same as above
Boxee to TV with cable 3 - splash screen shows, flashes to blue, then flashes to black and stays there. If I boot the boxee in recovery mode all is well and I get to choose from the menu, however even after a restore I still can't get past the splash screen
Boxee to Monitor with cable 3 - all is well, boots past splash screen and as normal.
The only thing I can think is that there is some issue with display/input modes on my TV. Either that, or one of the pair is just very fussy about HDMI cables. Any ideas on how I can resolve this? Would a different HDMI cable make a difference? I've attached the manual for my TV as a PDF if it helps at all!
To clarify further, I use a variety of other HDMI devices with no issues with cables 1/2/3, including Apple TV and PS3.
