Hey all - I'd appreciate some advice on an issue I'm having with this router.
Basically when I boot up my PC, which is wired via ethernet into my router, I will have continual drop-offs of internet connection for 20mins or so. It will connect, then drop for 5-10secs, then drop again after about 5secs and so on. It will do this continually but after 15-20mins or so will finally connect properly and not drop off any more.
When I plug in a different router model (BT hub) I get no drop offs at all.
I have tried different cables and ethernet ports. I also reported the router as faulty and a new one was sent out, however I am having the exact same issue with the new one. So either I have been sent two routers with the exact same issue, or my likely there is another problem which I cannot fathom
Any ideas what this issue could be? Thanks
