Question Issue with LG TV and Juddering 30 FPS PS4 game
wamid123
Could someone please watch the video I have attached to this thread to try and find out why the picture does this on my LG TV. I have no idea what it could be. The refresh rate for the TV I am playing on his 60hz and the game is running at 30FPS I believe. I am not sure if the FPS of the game I'm playing is the reason but whenever I play any game that runs at 60 FPS , it does not judder like this. I believe after lengthy research this is called JUDDER. Any help would be great as I am at a loss here, completely clueless.
I am playing on a standard PS4, running the game Dark Souls 3:Fire Fades edition.
Thanks guys.
Will
wamid123
Cannot upload a video so all I can describe it as my character in the game vibrating. If someone could suggest a way round this that would be great. Only way I can think is to email it personally or send on something like discord without converting the file. Thank ou
dts
Have you selected game mode on the tv?
What's the model number of the tv?
wamid123
I have mate. I've messed around with all the TV settings like TV judder, game mode... Everything the TV has to offer. Its an LG TV. Model number : 43UN74006LB. Strange thing is I never had this problem of juddering on my old TV.
Old tv: SAMSUNG UE43TU7100KXXU 43" Smart 4K Ultra HD HDR LED TV​
So confused. To describe juttering when I'm playing my video game on ps4 its not like it lags, like a frame drop, it's like the character vibrates when I walk slowly. Like I say I can send a video of it but not on this forum. It won't let me as the file is an mp4 file. Cheers for posting though pal, much appreciated.
mikej
Upload it to YouTube ?
Is your issue similar to the one in this thread ?
next010
Unsure if its the low fps stutter/judder issue, the UN7300 which should be similar to the UN7400 has a good low fps stutter score on rtings due to the panels slow response time, its near identical to the Samsung TV the OP had prior.
If you can try testing other 30fps games that have cameras you can control see if those judder too, maybe it's something specific to this game ?
wamid123
Thank you for the responses so far. Mike j it does not appear to be the same issue as the thread you linked in this one. I have uploaded the video to YouTube. Here is the link.
I have tried testing other 30 fps games next010 like monster hunter and the same thing happens on there. The Samsung TV is very similar and that's why I'm so confused.
next010
Yeah I see what you mean that is odd, not really sure what that is.
Only other suggestion I can make is this.
  • Change HDMI cable PS4 uses.
  • Change to another HDMI port on the TV and enable Ultra HD Deep Colour.
  • Select ISF Expert Bright Room as preset.
  • Go to the WebOS home screen/input manager and set the HDMI input label to PC.
  • In PS4 video settings set RGB range to Low/Limited.
This will activate a low latency mode over the ISF Expert Bright room preset, now try the PS4 and see if it behaves any differently. If not then I'm out of ideas, I'd consider returning the TV, perhaps its faulty.
wamid123
Ive got two LG TV'S, both a year old, both do the same thing. I've changed the HDMI cables and nothing. It also does this on my 19 inch Panasonic TV. It makes me think if it isn't the TV but what it is I have no idea. I will try the things you have suggested and let you know how I get on but I am doubtful.
Thank you next 010.
mikej
Yep - that looks really odd. I've had my PS3 and PS4 connected to a variety of TVs covering all the different technologies over the years (LCD, plasma, OLED and even CRT) and, while I have seen judder with some of these in certain low framerate games (similar to that shown in the other thread I linked to above), I've never seen anything like the behaviour shown in your example.
I think you're right in that it doesn't look similar to the usual low-framerate issue. If it was, in my experience you would see double-imaging of anything with a vertical edge (eg. building edges, lamp-posts etc) whenever you pan round, but the background in your video seems to be relatively unaffected - the problem seems to be associated with movement of the character's legs.
If you never had this problem with your old Samsung TV, then that proves it's not an issue with the game itself or console and probably not the HDMI cable, so it's hard to know what to suggest, especially if you've already tried playing with the TV's settings and gaming both with and without game mode. The usual suggestions for any TV-troubleshooting would be to check for the latest TV firmware and do a factory reset to start with. I can't see it helping in this case, but you've got nothing to lose and it would be the first thing any helpline would suggest anyway. Resetting the TV and starting from default settings can sometimes be helpful when trouble-shooting.
Have you tried playing with the motion interpolation settings ? It's not normally advised for gaming as it introduces latency/lag (it's usually disabled in game mode as a result) but lag doesn't tend to be an issue with a lot of the games I play and I found in the past that turning it on a low setting can sometimes smooth out motion issues for any problematic games. It could equally make things worse, but it's worth experimenting.
I would post in the LG TVs Forum to see if anyone else is having gaming issues with your TV.
next010
Thank you for the replies guys. Much appreciated. I will try what you have suggested.
If it happens on LG and Panasonic TV's then it may be the PS4 that is the problem.
Why the Samsung is not affected I do now know, perhaps some setting on it was masking the issue.
LG G1 OLED EVO Review (OLED65G1)
