Question Issue with dolby atmos & the panasonic SC-HTB700EBK
ajg007
I've been using the bar with no issues but now i can only get dolby atmos option if i use the usb c port from my graphics card which i didn't have to do yesterday!
Well then, use usb-c issue solved you say?
Well yes and no - if i set the dolby atmos option i can use the dolby access app but any non dolby atmos sound just makes weird popping and buzzing noises and then i have set windows to use 7.1 instead.
I've tried various HDMI cables just in case.. any ideas?
EDIT: i fluked a fix. I thought it must be a edid issue i found an monitor resolution program(cru) which had a reset-all.exe. Once i rebooted and sorted out my displays again all is working a again!
EDIT:forget above its to do with resolution!
