Monkeytrumpet
Hi all,
I have just set up my 5.1.2 atmos setup with a denon 2700H, cambridge audio minx surrounds and a minx 301 sub. Atmos works brilliantly, but the issue is the sub doesn't appear to 'kick in'. There is no audio at all from the sub, but if I pull the audio plug and put it back in, which probably isn't great for it, you get the typical buzz and thump of the plug connecting, and then the sub works as it should until next time. Crossover is set to 200, volume set to mid position.
Any ideas of what could be causing it? I'm at a loss!
Phil
Phil
