Isolation options
Discussion in 'Home Cinema Buying & Building' started by pringtef, Apr 17, 2005.
  1. pringtef
    pringtef
    Sep 30, 2003
    1,072
    Amsterdam
    +70
    I'm shortly to receive a room kit to assist with asorbtion and diffusion, but ideally i'd like to treat the walls and ceiling for better isolation prior to attaching these materials.
    Can anyone give advice on what options exist to help with isolation that do not require any DIY? Are there any adhesive materials that i can affix to the walls (plasterboard) prior to affixing the foam panels?
  2. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,181
    UK.
    +2,721
    When you say 'isolation', if you mean that to prevent sound traveling from one room to another, then only mass and an air gap will help do that, so DIY is required (new walls). If there was some magic product that could do that it would sell by the truckload. :)
    Gary.
