I want to make my own myself before my sub arrives next weekend
I will check again thksThat link gives the full specification of the screws doesn't it.....?
Nothing on link all it says the feet come with 3 sets of type of screws in the different sizes!!
You see I need to know which size the pb4000 would use ???
Doesn't show the PB-4000 on the compatibility list.....
Says Elastomer feet are included with the Sub.....
Hi I am aware it needs six feet I just need the screw size ????Yes it does, and specifies 6 feet are needed
That must be a M6 then??The manual states 1/4 thread size bolts
I'm sure I read somewhere that someone tried m6 feet on the SVS subs and they were a bit tight, so might have to find 1/4-20mm thread as per the SVS info
Yeah I no you weren’t dodge sorry if it came across that way.I wasn't quoting you.
Yeah I no you weren’t dodge sorry if it came across that way.![]()
That’s great thanks for that.
