isolate a sub?
Discussion in 'Subwoofers' started by grahamricho, Feb 21, 2002.
  1. grahamricho
    grahamricho
    Oct 29, 2001
    702
    York
    +13
    i,ve a kef thx sub which is in a cabinet which i built to house my speakers .the problem i,m having is the sub fires through a speaker cloth grill at the front and theres 6 inch allround the sub which is directly on the concrete floor.the sub makes the whole cabinet rattle at high volumes.how could i isolate it.would rockwool insulation work or spikes,or another suggestions,i would of thought the rockwool would not do much due to the low frequencys,any thoughts cheers graham
  2. Electric Mayhem
    Electric Mayhem
    Mar 16, 2001
    10,464
    United Kingdom
    +1,933
    I´d give spikes a go first of all and then maybe get some carpet in there for the floor as well.
    There is always trusty blu tac as a last ditch attempt to stop rattles (actually works quite well, stopped all mine!!).
