Iscan with Sharp XV-z91
Discussion in 'Projectors, Screens & Video Processors' started by KeithO, Jul 3, 2003.
  1. KeithO
    KeithO
    May 28, 2003
    1,434
    63
    Erding, Bavaria
    +214
    Do any of you knowledgeable chaps (and chapesses :D ) think it would be worthwhile adding an Iscan Pro to my Sharp XV-Z91 DLP projector? And would it be complete overkill to try an Iscan Ultra?
    I'm not enormously well up on the technicalities of line doublers and scalers and stuff so a bit of advice in layman's terms would be appreciated.
    TIA
  2. KeithO
    KeithO
    May 28, 2003
    1,434
    63
    Erding, Bavaria
    +214
    No-one?! :confused:
  3. yatesd2404
    yatesd2404
    Wondered about this as well, as Sky broadcasts really do suffer on the big screen.
    No one got any thoughts??
    I have searched back through the forums and seems like everyone raves about the improvements to be had by going with the Iscan.
    Dave.
  4. asle
    asle
    Hello KeithO,
    can't help you with your original question, but hope you can help me.
    I was planning to get the sharpz90, but I understand the z91 can give a larger projection on a shorter distance right?!
    Well, as my projection wall space is limited physically, I would like to find out the projection size compared to projector distance, so I can see if gteting the z91 would be worthwile.
    I suppose this size-distnace matrix is in your manual, would you be so kind to see if you can give it to me?
    What's your opinion on your z91, is it noisy? did you mount it on the ceiling? anything you don't like about it?
    cheers!
  5. filmman
    filmman
    Nov 10, 2001
    273
    2
    brighton
    +7
    hi
    yes the z91 does give a large image in a small room. 2m projector to screen gives me an image 5ft wide. the picture is outstanding,no rainbow effects,needs a fully darkened though.
    my advice,buy one.
    p.s. i will be borrowing a friends iscan box next week,will post my comments.
  6. Gordon @ Convergent AV
    Jul 13, 2000
    14,207
    +3,042
    The reason there are no answers is that I guess no-one has tried it to see. How much of an improvement depends on the qality of the video processing inside the projector.
    In the projector the incoming analogue signals go through a colour TV decoder, are digitised, go through a de-interlacing solution then a scaling one until they finally drive the panel. Plenty of areas where PJ manufacturers generally scrimp on costs.
    Products like external video processors are optimised to get the best picture quality from a moving image. Of course, even then not all are created equal. See if you can borrow an Iscan and see if you can borrow one of the Lumagen Vision scalers I distribute as well as that could be another great option (at greater cost though)
    Gordon
  7. KeithO
    KeithO
    May 28, 2003
    1,434
    63
    Erding, Bavaria
    +214
    asle, I am very happy with it...great picture, no rainbow (that I can detect anyway, but some people are more susceptible than others). I have it mounted on a stand (like a tall coffee table). It's not especially noisy, unnoticeable if you have a decent surround sound system. The z91 is exactly the same as the z90, except for the short throw lens
    you can get a copy of the manual here:
    http://www.sharp.co.uk/products/product.asp?id=676
  8. Messiah
    Messiah
    Apr 22, 2002
    7,616
    +338
    KeithO
    Another option is I have a Quadscan pro which has an option to utput an SVGA (800x600) signal which I believe is the resolution of the Z90/Z91 panel.
    When I tried an iScan pro and a Centrestage CS1 in place of the QS Pro a while back I could see absolutely no difference whatsoever, so determined that the QS Pro was a s good as them.
    Why am I saying this? Well, I am looking to sell the QS Pro so if you wanted to try it out then for the cost of postage only I would be willing to send it to you to try. If it did then you could send a cheque, if not then just return it. Obviously I would siomply ask that you look after it. If this appeals to you then please let me know.
    BTW, the classified thread for it is http://www.avforums.com/forums/showthread.php?s=&threadid=85490
  9. KeithO
    KeithO
    May 28, 2003
    1,434
    63
    Erding, Bavaria
    +214
    Gordon, thanks, I'll see if I can borrow one.
    filmman, let me know how it looks.
  10. filmman
    filmman
    Nov 10, 2001
    273
    2
    brighton
    +7
    hi keitho
    tried a iscan pro,looks great.image a lot cleaner,better detail and the picture seems brighter. no picture drop out or freezing
    i have only watched two films with the iscan( The Hours and Gangs of New York) so i will post again soon.
