ISCAN - what does it do??
Discussion in 'Plasma TVs Forum' started by FaxFan2002, Jul 17, 2003.
  1. FaxFan2002
    FaxFan2002
    Jan 25, 2003
    2,422
    63
    Andover
    +159
    I have seen a lot mentioning of the ISCAN ultra thingymijig - basic questions is what is it and what does it do?
    Would it be applicable in my scenario where everything goes into a video switching amp and then output to the panel (apart from the dvd which will have a direct connectionto panel via compon. connections) ? I will (panel arrives monday) be using S-Video (for NTL cable, XBox,DVD recorder) & Composite (PS2, GameCube and owt else).
    Comments, suggestions and experience welcome!!
    Cheers,
    Robin.
  2. Urotsukidoji
    Urotsukidoji
    Feb 20, 2003
    262
    19
    Greenwich, London
    Why are you using svideo and Composite?
    Anyway, the iscan ultra is a deinterlacer - you send it interlaced stuff and it spits out p. scan stuff. Wether you need it or not depends on what display you use - what model plasma have you ordered?
  3. tbrar
    tbrar
    May 31, 2003
    609
    16
    FanFax2002,
    The Iscan is a de-interlacer with some additional benefits.
    Basically you put an interlaced signal in, get a progressive signal out. Output, via both digital and analouge, up to 576p.
    I would imagine usefull if you havn't a progressive scan DVD player or indeed want to improve 'television' picture performance.
    In your scenario, DVD if not Progressive, via the ISCAN as could NTL. Have a look at www.tmfsolutions.co.uk for more information.
    Ive not used one before, so no idea of how good the quality of output is.
    Tony
