Iscan Ultra Pt-ae300 and DVI
Discussion in 'Projectors, Screens & Video Processors' started by Ianfromnotts, May 20, 2004.
  1. Ianfromnotts
    Ianfromnotts
    May 16, 2003
    2,760
    Nottingham
    +174
    Before i throw away ( return to Lindby) the new DVI cable I have just bought is there any magic tricks I can try to get the DVI to DVI connection to work between th ultra and the panny. Screen is blank as if their is no signal book seems to suggest that it only works on US signals or could it be that the panny wont accept the signal - couldnt get it to work on 750p either. Any ideas other than back to component cables?
  2. loonatic
    loonatic
    Jan 4, 2003
    1,925
    41
    Springwell Village, Gateshead
    +16
    I had limited success in using the DVI out of the Ultra with my HS10 PJ when I had it.
    I got a picture but it seemed to be chopping off the bottom 1/8th of the image...apart from that the picture was sweet - better than via YUV - much smoother and cleaner looking.
    Cheers, Lee
