ISCAN Ultra configuration question
Discussion in 'Projectors, Screens & Video Processors' started by JUS, Dec 23, 2003.
  1. JUS
    JUS
    Jan 21, 2003
    3,432
    Plute
    +320
    The YC Delay and Sync options have me stumped. I can't see any difference in the picture when I change these. Can anyone give me an example of how I can see the difference when changing the settings?
    I have a Pio565 connected via component to Ultra. VGA to Component lead out of Ultra to Z1.
    Jus.
  2. jmack
    jmack
    go onto a dvd menu with writing or a nice box to look at or on sky use the clock on sky news .
    as you adjust the y/c delay you will see the shadow i call it behind the box/writing move from side to side till you get it spot on, ntl digital you mine dont need moving stays on 0.
    not sure about sync i supose if its wrong you wont get a picture.
    hope that helps
  3. JUS
    JUS
    Jan 21, 2003
    3,432
    Plute
    +320
    Thanks jmack. I'll try yc delay tonight.
    sync - I can scroll through all the settings and it doesn't seem to do anything (H+V, SOG, CSY). to choose the "output timing signal compatible with your display" ???
    Jus.
  4. Dale Adams
    Dale Adams
    Jul 9, 2003
    175
    +15
    Your display may simply be able to accept any of these sync types. Some displays are very picky and only want to see one particular type of sync, while others are 'sync-agnostic'. Yours would appear to be of the latter type.
    - Dale Adams
