Iscan Ultra advice needed
Discussion in 'Projectors, Screens & Video Processors' started by DaveP, Mar 24, 2005.
  1. DaveP
    DaveP
    I've recently bought a Sony HS20 pj and I'm connecting up my Sky+ via an RGB to Component converter.
    The pq is good but not what you would call very good or excellent.
    I just bought a TV-100 card to use to capture the s-video outut from the sky+ and the picrure, through Dscaler, is not as good as the existing connection.
    Both images are soft bordering on blurred.
    The PC is connected via DVI from my ATI 9600SE card and the res is set at 1366x768. The info on the pj shows as a 1366x768 also.
    So (finally) the question is: Should I buy the Iscan Ultra that is in the FS Forum? Would this give a sharper image?
    Would this be the most cost effective solution or should I try the Sweetspot?
    SWMBO is not happy with the money I've already spent on pj, cables, screen etc so a budget of about £250 is the max.
    Or should I just accept that the picture is as good as I can expect from sky on a six foot screen?
    Thanks for any suggestions
    Dave
  2. David PluggedIn
    David PluggedIn
    Oct 14, 2003
    544
    +10
    Hi Dave
    assuming that you have a razor sharp, 1:1 mapped image from your pc to the projector then SweetSpot should happily do the business for you, while maintaining domestic bliss at the same time :)
    The softness you are seeing isnt Sky, its the budget tv card :(
  3. DaveP
    DaveP
    Thanks David, I appreciate you taking the time to respond, certainly seems like no-one else was going to!
    As luck would have it, a sweetspot came up for sale so I have gone for that.
    I'll let you know how it goes!
    Dave
  4. Vince M
    Vince M
    Nov 2, 2004
    473
    19
    Lagoa
    :thumbsup:
    Yes Dave,go for the I-SCAN HD+ if you can,its future proofed with the HDCP compliance on the DVI input and one of its output resolutions is 1366 x 768.
    Having owned the ATI 9600se I can testify that the scaler is better with this res.
  5. DaveP
    DaveP
    Thanks for the suggestion. I'd dearly love to get one, but it's way outside my budget!
    Dave
  6. David PluggedIn
    David PluggedIn
    Oct 14, 2003
    544
    +10
    Hi Dave
    sounds like a result :) While you will get improved SVideo performance just doing a like for like swap, you are best using the RGBS connections...but then you already knew that and I am just stating the obvious :)
  7. DaveP
    DaveP
    It comes with the scart lead, it won't be long enough though. Initially I shall have to try the component in from my RGB/Component converter.
    Dave
