iScan problems
Discussion in 'Plasma TVs Forum' started by Claus, Jul 2, 2004.
  1. Claus
    Claus
    I am testing an iScan HD. Sending a component signal from the DVD player and component signal out from the iScan.
    My problem is that when I'm watching PAL movies with a 1080i resolution the picture is leaning to the right side of the screen. This doesn't happen with NTSC material.
    Can someone explain what to do?
    Claus
  2. Maninblack
    Maninblack
    Sep 24, 2002
    458
    +17
    Post in the Progressive Scan and Video Processing forum and Dale Adams will fix this I would hope!
