Iscan Pro to Seleco 400HT Connection
Discussion in 'Projectors, Screens & Video Processors' started by mortonman, Aug 1, 2003.
  1. mortonman
    mortonman
    Having just purchased an Iscan Pro from a fellow forum member, and well pleased with that. I am after some advice on what the best way to connect it to my projector which is a Seleco 400HT. I don't know whether it is VGA or the other options.
    Which will give me the best picture ?
    Matt:confused:
  2. popeye
    popeye
    Feb 12, 2002
    779
    19
    Leeds
    I used to own a 400 and I also used an iscan Pro. The best way to connect the two is to use as a 15 pin D ring to 5 BNC break-out cable to your 400. For best results use a component video cable to the iscan from your dvd player.
    You will notice a big improvement with the iscan over the internal up-convertor in the Seleco.
    All the best!
    popeye
  3. AndyFov
    AndyFov
    Nov 20, 2002
    1,395
    March, Cambs
    +35
    There's an Iscan Pro on the classifieds, and I'm buckling...
    How much should I budget for a decent breakout cable? And any pointers as to where I could get one from? I'd be looking at 10M.
    I've seen Keene do a 15pin VGA to 3 BNC, presumably my Seleco 400 won't be able to take the sync from green?
    TIA
    Andy
  4. popeye
    popeye
    Feb 12, 2002
    779
    19
    Leeds
    You will need a 15pin to 5 BNC for your 400. Have a look at the accessories page at www.crtprojectors.co.uk
    They stock what your looking for.
    Regards
    popeye
