IScan Pro to Hitachi TX100 (VGA to ?)
Discussion in 'Cables & Switches' started by gossp, Sep 1, 2004.
  1. gossp
    gossp
    Nov 5, 2002
    388
    Lincolnshire
    +7
    Quick question for you all?
    Just bought myself a 2nd hand IScan pro :thumbsup:. It ony has a VGA output. My PJ (Hitachi TX100) has all manner of inputs. Which should I use/will give best quality picture?
    I guess the important inputs that it has are Component, DVI-D and VGA?
    So should I just buy a VGA to VGA cable or should I get a VGA cable with a different connection type (DVI or 3 x RCA)?
    Also can anyone recommend a good quality (not too expensive) cable of the type recommened?
  2. SamirP
    SamirP
    Apr 28, 2003
    1,303
    South Of The River
    +38
    VGA to VGA is all you need :thumbsup:
  3. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    27,014
    The Borders
    +3,161
    gossp
    I'd normally supply a VanDamme Red Series VGA cable along with the iScan Pro, Ultra and HD for Analogue connectivity.
    On the majority of displays (PJ or Plasma) your best using RGBHV from the Pro - though you can also set it to output YUV from the HD15 socket.
    It is possible to get an HD15 to DVI or HD15 to YUV (3RCA) cable but I cant imagine they will be any better than HD15 to HD15.
    Best regards
    Joe
  4. gossp
    gossp
    Nov 5, 2002
    388
    Lincolnshire
    +7
    Thanks Guys,
    I already have a VanDamme component cable and am very happy with its quality. How much are the Vga cables Joe?
