Iscan pro scaler problem
Discussion in 'Projectors, Screens & Video Processors' started by scott33b, Dec 4, 2004.
  1. scott33b
    scott33b
    Aug 3, 2004
    68
    Hi. Can anyone help with a problem??. When the Iscan is set to RGB I get an offset band about 6" wide at the top of the screen, which I can only describe as a squiggle. When I switch the Iscan to YPbPr the picture is perfect except it is very green.
    The Iscan Pro is second hand, but in excellent condition.
  2. BertM
    BertM
    Oct 3, 2004
    41
    You could try to set the synch signal to a different type, it's now probably set to Bi-Level or Tri-Level, set it to composite or any of the H/V options.
    (Output Setup -> Sync Type)
    Good luck!
    Bert
