iScan Pro Question
Discussion in 'Projectors, Screens & Video Processors' started by Lynchpin, Feb 13, 2003.
  1. Lynchpin
    Lynchpin
    To save me digging out the manual, wherever that may be...
    On Convergent's site it is stated that the iScan can output component video, is that the case? (http://www.convergent-av.co.uk/video.htm)
    The reason for this is that i would like to take component from the iScan into an HS10 and this appears a reasonable way of doing so, bearing in mind that it so happens I own an iScan. But on the back of the unit the only thing labelled "output" is the VGA, so I'm confused :confused:
    Can anyone shed some light?
    Ta
    K.
  2. rhinoman
    rhinoman
    Oct 31, 2000
    2,631
    71
    Herne Bay, Kent
    +33
    A vga to component lead?
  3. Lynchpin
    Lynchpin
    Yeah i thought that too and went hunting last night for one, with the help of Google and failed to turn anything up at all. :/
  4. rhinoman
    rhinoman
    Oct 31, 2000
    2,631
    71
    Herne Bay, Kent
    +33
  5. bxd
    bxd
    Oct 17, 2001
    1,487
    Southampton
    +134
    Presumably the component video uses the three cables (and their associated ground connectors) that are normally used for the red, green and blue (and ground) signals from the vga connector. If that's the case you could use a vga to 5x bnc computer monitor cable and use bnc to phono adapters.
    You need to change around some switches (or pins) INSIDE the iScan to set the output to component.
    Brian
