iScan Pro HD +
Discussion in 'Projectors, Screens & Video Processors' started by Edgeyboy, Nov 4, 2004.
  1. Edgeyboy
    Edgeyboy
    Jul 31, 2000
    3,497
    Norfolk
    +168
    I am thinking of buying an iScan Pro HD +.
    I want to connect my Pioneer 868 by HDMI to DVI-D (HDCP) interlaced to the iScan, let the iScan scale it (perhaps to 720p), and output it by analogue RGB plus SYNC to my SONY CRT.
    Will it let me do this ?
    Many thanks.
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    not sure about HD+ but Iscan HD DVi input was a passthrough so didnt scale the image just allowed you to use iscan and DVi source into display as most only have one DVi input
  3. Laura
    Laura
    Mar 8, 2002
    397
    Newcastle Upon Tyne
    +24
    I believe as with other HDCP compliant scalers, the IScan HD+ won't output HDCP encoded material via analogue, only by the DVI output.
  4. Edgeyboy
    Edgeyboy
    Jul 31, 2000
    3,497
    Norfolk
    +168
    Thanks for the replies.
    What I want to avoid is the extra A/D conversion, hence the question.
    Will the iScan HD+ allow conversion from DVI (HDCP) to RGB HV without scaling then ?
    If the iScan HD+ won't allow it, will any others ? I think Crystalio does by SDI but it is a little rich, financially, for my blood.
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    why convert DVi-D to RGBHV?
  6. Laura
    Laura
    Mar 8, 2002
    397
    Newcastle Upon Tyne
    +24
    Pretty sure none of the scalers will do want you want.
  7. Gordon @ Convergent AV
    Jul 13, 2000
    14,210
    +3,048
    No scalers will take in an encrypted digital signal and output them analogue. Many will take in an unencrypted digital signal and output it analogue (SDI with Iscan/Crystalio/Vigatec/FocusEnhancements and of course....Lumagen).
    Gordon
  8. Edgeyboy
    Edgeyboy
    Jul 31, 2000
    3,497
    Norfolk
    +168
    Thanks for the replies guys.
