iScan HD
Discussion in 'Projectors, Screens & Video Processors' started by chriswhiteuk, Jun 18, 2004.
  1. chriswhiteuk
    chriswhiteuk
    Sep 30, 2002
    264
    Surbiton
    +6
    I've just received my IScan and have only just figured out that I can't use it with my Sony 930v component out as it doesn't accept the signal . . .
    works with NTSC DVDs, but not PAL . . .
    is this correct before I sell it ?!
    Chris
  2. rscott4563
    rscott4563
    Jan 21, 2003
    1,054
    38
    Cumbria
    First thing I'd say is, if you do decide not to keep it, don't sell it!
    DVDO offer a 30 day money back guarantee so just take it back to where you got it from and get your money back...
  3. Jasonjo
    Jasonjo
    Dec 3, 2001
    2,677
    UK
    +115
    Have you spoke to DVDO tech support to double check it wont work?
    You could also post a bit more info and maybe Dale Adams from DVDO will help??
    Otherwise try posting on www.avsforum.com video processors forum as they have a dedicated iScan HD thread...
    JJ
  4. chriswhiteuk
    chriswhiteuk
    Sep 30, 2002
    264
    Surbiton
    +6
    Hi, sorry, I was a bit brief !!
    What I am trying to do is upscale the component output from my DVD player for display via DVI on my Panny AE500.
    The problem I am getting is no image when using PAL discs, but NTSC material looks awesome.
    I have contacted the mentioned, and am awaiting replies.
    Was in a of a panic/stress this morning when it wasn't working !!
    Chris
  5. rscott4563
    rscott4563
    Jan 21, 2003
    1,054
    38
    Cumbria
    The iScan HD definitely accepts a component Pal (576) signal in either interlaced or progressive so either you have a problem with your dvd player, cabling, faulty iScan HD, or most likely an incorrect setting on your iScan...
  6. jmack
    jmack
    or maybe the panny dont like pal through dvi? like there plasma`s dont
  7. chriswhiteuk
    chriswhiteuk
    Sep 30, 2002
    264
    Surbiton
    +6
    got to be a setting thing, I'm going through everything again now. As said, the picture is really good with NTSC, so the cabling is good.
    I didn't know about the PAL via DVI problem !
    Chris
  8. Jasonjo
    Jasonjo
    Dec 3, 2001
    2,677
    UK
    +115
    Does the AE500 support PAL progressive via DVI?...sounds like it only supports NTSC progressive????
    JJ
  9. jmack
    jmack
    there plasma`s dont like pal through dvi.
    i dont know about the projector`s i`m guessing.
    are you on the latest iscan hd software
  10. Jasonjo
    Jasonjo
    Dec 3, 2001
    2,677
    UK
    +115
  11. rscott4563
    rscott4563
    Jan 21, 2003
    1,054
    38
    Cumbria
    Why not just try feeding the iScan with Pal from the dvd player and tell it to frame rate convert to 60Hz, if that works then its obviously the fact that the display can't handle the resolution you are trying to feed it at 50Hz, if it doesn't work then its a problem with the dvd player and iScan..
  12. chriswhiteuk
    chriswhiteuk
    Sep 30, 2002
    264
    Surbiton
    +6
    working :clap: :smashin:
    Many thanks to all !!
    The PJ would take the 50 or 60HZ setting straight off the menu, but creeping up in the custom mode to 59.9, it synced !!!
    Quality picture now, cheers guys !
    Anyone after QED 5m component leads hehe
    :hiya:
  13. rscott4563
    rscott4563
    Jan 21, 2003
    1,054
    38
    Cumbria
    Really glad to hear that you got it sorted.. :smashin: :clap:
  14. petrolhead
    petrolhead
    Mar 29, 2002
    4,794
    87
    Newcastle
    +116
    So how much of an improvement has it made?
  15. chriswhiteuk
    chriswhiteuk
    Sep 30, 2002
    264
    Surbiton
    +6
    Over the standard component feed from the DVD player in progress (via QED leads) made an amazing transformation. Biggest improvement was the lack of noise via the DVI connection.
    I also tried the Freeview box via SVHS feed in the iScan, and even this looked a whole lot better than the SHVS feed direct to PJ. TBH the difference is hard to describe, just looked a lot more solid.
    I just got a Pioneer 868 but not the HDMI cable yet. So I compared the component feed straight to the PJ and via the iScan. The difference is still noticable, the iScan making the image much smoother and cinematic.
    However, I haven't had a chance to try the Pio via HDMI-DVI yet - fingers crossed it will be good :rolleyes:
    The Pio blows away the Sony, nuff said. But it does cost roughly four time the price, so is expected. I let out a big sigh of relief when I first saw the PQ :)
    my iScan is on Ebay . . . . so is the DVD player, lol
    Chris
  16. petrolhead
    petrolhead
    Mar 29, 2002
    4,794
    87
    Newcastle
    +116
    Cheers for the reply Chris. YHM
