iscan HD test Patterns
Discussion in 'Projectors, Screens & Video Processors' started by vancouver, Feb 20, 2005.
  1. vancouver
    vancouver
    I am annoyed. Why is it when I set the frame rates to 72 hz then do the test pattern of the white bar going side to side the is more "judder" then when I set it to 60Hz? Shouldnt that effect be just the opposite?
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,930
    The Borders
    +3,573
    vancouver
    How much judder (or not) you see will depend on the Input signal your working with and what your Display does with the Output signal your sending it.
    The majority of Displays will Frame Rate Convert the Incoming signal to best suit the Display - everything is interactive; find what looks best on your set-up and avoid the 'higher is better' fallacy.
    Best regards
    Joe
  3. vancouver
    vancouver
    thanks for the advice. Are some DVD players better then others when it comes to how high of a frequency it can send out?
  4. Gordon @ Convergent AV
    Jul 13, 2000
    14,245
    +3,111
    DVD players will send out the refresh rate native to the signal they are playing. IE R2 DVD will be 50Hz and R1 will be 60Hz.
    Gordon
