iScan HD Software Update
Discussion in 'Projectors, Screens & Video Processors' started by Clamicpo1, May 23, 2004.
  1. Clamicpo1
    Clamicpo1
    Dec 12, 2002
    7,847
    Alvaston/Derby
    +265
    Hi, I'v tried to update the software but when the transfare reaches about 1200 bytes the iScan HD comes up with ERR1. I'v tried it on different PC's but I get the same error, can someone help me as the machine is unusable like this. Charlie
  2. Dale Adams
    Dale Adams
    Jul 9, 2003
    175
    +15
    I suggest that you try downloading the .abt file again. Perhaps it has become corrupted somehow, and that is what the iScan is complaining about.
    - Dale Adams
  3. Clamicpo1
    Clamicpo1
    Dec 12, 2002
    7,847
    Alvaston/Derby
    +265
    Hi, I've tried downloading the file several times & still et the same error message (ERR1). At the moment the only wires connected are the mains & the serial cable, I have tried it with the screen connected but I always get the same message, Charlie
  4. Dale Adams
    Dale Adams
    Jul 9, 2003
    175
    +15
    Send an email to [email protected] and describe what you're seeing. They should be able to help.
    - Dale Adams
  5. jmack
    jmack
    is this a newer software than the one that was released a bit early a few weeks back.
  6. Clamicpo1
    Clamicpo1
    Dec 12, 2002
    7,847
    Alvaston/Derby
    +265
    Hi, I havent got a clue, I got an email fromm DVDO informing me that iScan HD Firmware Version 1.08 is Now Available. Charlie
  7. Jasonjo
    Jasonjo
    Dec 3, 2001
    2,687
    UK
    +116
    Yes it is slightly newer and is now public release, as opposed to beta. Check the release notes...
    JJ
  8. jmack
    jmack
    cheers jasonjo
  9. Clamicpo1
    Clamicpo1
    Dec 12, 2002
    7,847
    Alvaston/Derby
    +265
    Has anyone installed the new software.
  10. jmack
    jmack
    yes just installed it.
    ps. my apologies it seems it works fine if i change the setting on from wide to narrow on the sync setting on my plasma.
    i like the way the test patterns are filed now.
