iScan HD Settings for Panny PW6
Discussion in 'Projectors, Screens & Video Processors' started by PaulCaden, May 13, 2005.
  1. PaulCaden
    PaulCaden
    Jun 7, 2004
    87
    +3
    I will (hopefully) be taking delivery of an iScan HD shortly and would like a gentle push in the right direction re resolution and frequency settings etc.
    The input to the plasma will be via PC - all inputs to the iScan are component.
    Any pointers/tips would be greatly appreciated.
  2. Jase
    Jase
    Mar 16, 2001
    9,315
    South Coast
    +827
    Whilst I don't have an Iscan you could try 720p @ 59.94hz for NTSC and 600p @ 50.00hz for PAL. Output from my Lumagen is RGBHV into the PC Input on my Panny 42PWD6. :)
  3. PaulCaden
    PaulCaden
    Jun 7, 2004
    87
    +3
    Thanks for this. And how is the picture quality compared with the 'au natural' settings of the Panny?
  4. Jase
    Jase
    Mar 16, 2001
    9,315
    South Coast
    +827
    These give me the best image quality. I've also tried 480p direct from the DVD player via Component as well as 480p, 576p and 720p via Component from the Scaler. Can't try anything else direct as I only have the standard PC Input and the BNC Component Board.
  5. Jasonjo
    Jasonjo
    Dec 3, 2001
    2,648
    UK
    +112
    I use RGBHV with 720p and 50Hz locked as 50Hz and 60Hz locked as 60Hz.
    The SD Pannys are known to give their best via analogue using 720p due to oversampling.
    Theres quite a lot of info on settings and setup if you have a dig in this forum (quite a few posts by me ;-) )
    Enjoy the new toy, once setup it realy does get the best out of the screen...
    JJ
  6. PaulCaden
    PaulCaden
    Jun 7, 2004
    87
    +3
    Got the new toy! Looks awesome on 576p - tried 720p but the I don't see the whole picture (the right edge is off the screen) and I can't figure out how to make the screen fit apart from fiddling with the actual screen controls. Shrinking the picture down this way leaves the control setting positions looking at bit extreme! Hope I'm making sense...
    I feel I'm missing out :(
  7. Thatsnotmynaim
    Thatsnotmynaim
    Jun 21, 2004
    2,326
    Middle Earth
    +127
    Hi just had mine a few days now, this is what I have done so far.
    1. Plug the iSCAN into the PC input on the TV, set the output to XGA.
    2. Set the Framerate 50Hz > 50 Hz Lock & 60Hz > 60Hz Lock.
    3. Then look at the test patern 1 (FGEO) and make it fit the screen using the TV's remote (Picture pos/size) H+V-Size & H+V Pos.
    4. Then next tweak it to get 1:1 pixel match, go to the test patern 4 (VLIN) and use the H-Size on tv to get rid of the moire pattern (1:1 pixels), once done, flick back to test patter 1 and center using just H-Pos. Now do the same the other way, go to test patter 5 (HLIN) adjust using V-Size to get rid of moire, then once done center using test pattern 1 and just V-Pos. Now put on an NTSC DVD and repeat.
    This is as far as I have got so far. Any tips appreciated! :)
  8. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    Tip 1:
    Get peirs to come and ISF it, with the screen set to optimum and the Iscan feeding it optimum you will have an incredible setup............. see www.homecinemaengineering.com for more details
  9. Thatsnotmynaim
    Thatsnotmynaim
    Jun 21, 2004
    2,326
    Middle Earth
    +127
    I would definately, but I think I'll wait till I get a PHD8 in the autumn before getting an ISF expert round!
    Seems a bit of a waist for just 4-5 months and then do it all again. Also hopefully I'll be spending too must of the summer in a beer garden somewhere! :D
  10. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    LOL upgraditis?
  11. Thatsnotmynaim
    Thatsnotmynaim
    Jun 21, 2004
    2,326
    Middle Earth
    +127
    Hmm, maybe a little. I've just borrowed a Naim DVD5 from my local dealer! WOW, I may not take it back.
