iScan HD & Pioneer 434 - native res question
Discussion in 'Projectors, Screens & Video Processors' started by kevshed, Jul 31, 2004.
  1. kevshed
    kevshed
    Oct 30, 2002
    1,249
    48
    bournemouth
    +98
    Hi guys,
    Im having difficulty getting my iScan HD to drive my plasma at native resolution.
    As you all know, the pioneer is 1024x768 native - which should relate to 'XGA' output setting on the iScan.
    Problem is, if i select this, the picture is offset by a massive amount (at least half a screen off) and the UI of the iScan becomes really large. Clearly something not right.
    In terms of hookup, the iScan is connect to the Pioneer reciever from DVI-> HDMI.
    Any help here appreciated. Im currently sending out 720p, and the de-interlacing is appauling (very visible indeed on credit sequences and the sky news ticker)
    Thx
    Kev
  2. Dutch
    Dutch
    Dec 5, 2002
    2,601
    2
    5
    North Yorkshire
    +284
    kev,
    Unfortunately the HDE models won't accept native res on HDMI - nice one Pioneer. :suicide:
    Steve
  3. kevshed
    kevshed
    Oct 30, 2002
    1,249
    48
    bournemouth
    +98
    your kidding me..... any idea why that is?
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    possibly as pio were the first the Chipset is only 480 or 576 capable, should be able to do it on component tho!
  5. kevshed
    kevshed
    Oct 30, 2002
    1,249
    48
    bournemouth
    +98
    ok, so i have not hooked up the component - and switched off all all the HDMI (hmmm good investment that was!). But even so, at XGA, i get no picture. In fact, i only successfully get an image at 576p.
    All very odd. I wil mess around with the sync tomorrow.. perhaps its the lock it doesnt like.
    Grrr...
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Iscan HD has got a software update available, contact your dealer about upgrade or see DVDO site all you need is a 9 pin serial cable.
  7. kevshed
    kevshed
    Oct 30, 2002
    1,249
    48
    bournemouth
    +98
    your right.. they do. I'll grab the latest and try it. Thx.
    Waiting for DVE to arrive this week, so i can calibrate this thing as best i can.
    Cheers,
    Kev
  8. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    the Iscan HD has a known issue with component which is fixed in software update. with Pio not support 720p on HDMI you have fallen a bit foul mate!
  9. Gordon @ Convergent AV
    Jul 13, 2000
    14,214
    +3,055
  10. kevshed
    kevshed
    Oct 30, 2002
    1,249
    48
    bournemouth
    +98
    hmmm ok well, i'll update the iScan. Frankly, if after this, im not seeing an improved image, their will either be an iscan for sale... or worse case... an HDE for sale!
    thx for the advice.
    Kev
  11. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    LMK how you get on mate.
  12. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    try using 1080i as well works great on a 504 so i have have heard...
  13. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    You are not getting good advice here mate. The Pio will not accept native on HDMI, but will accept 1080i or 720p, set the iscan to this and connect DVI-HDMI, unless you can do VGA into the front of the box, which will accept native XGA. The 434 component input is at fault, not the iscan. It only accepts PAL or NTSC, ie 575 or 480. there is nothing wrong with the iscan's component output that I have found. Yes it's a shame the 434's digital output is nobbled, all to do with 'channels', you have a consumer product, you are therefore not interested in technical matters, you just want to plug and play. It is indeed your 434 which needs to go if you want to play with big boys toys, shame on you Pioneer. And it looks soooo sexy! I knew a woman like that once....
  14. kevshed
    kevshed
    Oct 30, 2002
    1,249
    48
    bournemouth
    +98
    thanks for the post.
    So far, ive been unable to update the software in the iSCAN. 5 computers in the house... but do i have RS232 on any of them? nnnnnnoooooooo Great.
    Gonna play with DVE tomorrow, If im pleased with the results, then i'll keep it. If not.... a tough conversation with the mrs..... :)
  15. oferlaor
    oferlaor
    Aug 4, 2004
    10
    buy a USB->RS232 cable converter. You might want to contact DVDO first, because there are some issues with a few of these converters cables.
    About your specific issue, first, switch your iScan HD to "advanced" mode. Second, make sure you are using unlocked 59.94Hz as your vertical refresh rate for PAL too! That could fix your native rate issue (you need to check the judder test pattern afterwards to ensure that you're not introducing too much judder because of the frame rate conversion).
    Then, if you still can't get proper 768p to work, start playing with the advanced timing options. See how each parameter affects the image (the back porch in particular)!
    You can check if your settings are correct by using the iScan's overscan pattern.
    If you do get native rate (i.e., overscan pattern showing no missing areas and the vertical and horizontal stripe patterns show up correct) - make sure to post the advanced timing numbers.
  16. kevshed
    kevshed
    Oct 30, 2002
    1,249
    48
    bournemouth
    +98
    Right - well after spending the whole weekend messing around with timings, test patterns, DVE and generally driving myself up the wall, ive given up.
    I need an expert to come and calibrate my video side - anyone on the south coast an expert in these things?
    Thx
    Kev
  17. Gordon @ Convergent AV
    Jul 13, 2000
    14,214
    +3,055
  18. zAndy1
    zAndy1
    Nov 26, 2002
    22,542
    2
    5
    163
    +8,949
    lol, you sound just like me! I can certainly recommend Gordon though, geez does he know what he's doing! Sorted my Lumagen/Plasma out and I wouldn't have had a chance!
    Cheers,
    Andy
  19. kevshed
    kevshed
    Oct 30, 2002
    1,249
    48
    bournemouth
    +98
    Gord you have mail !
    Much as im an advocate of having a go - there comes a time when you have to accept help !
    Thx for all the advice provided on this thread.. very helpful.
    thx
    Kev
  20. drago.d
    drago.d
    Apr 25, 2003
    172
    Kings Langley, Herts
    +9
    Any further news on your 434HDE & iScan issues?
    I have same plasma and am considering my scaling options, so your feedback here is particularly relevant .
    regds,
    drago.d
  21. kevshed
    kevshed
    Oct 30, 2002
    1,249
    48
    bournemouth
    +98
    I had gordon come down and calibrate my setup; after a few hours work, my SKY image was improved a little, but this was mainly due to the ISF calibration that Gordon did. The scaling did a little but it didnt excite me much.
    As for de-interlacing. We found that my FMJ DVD Player did a better job de-interlacing that the iscanHD did.
    All in all, because you cant pixel match the display, i think there is limited value....
    hope this helps.
    Kev
  22. Gordon @ Convergent AV
    Jul 13, 2000
    14,214
    +3,055
