iscan HD lip-sync functionality
Discussion in 'Projectors, Screens & Video Processors' started by diabolik, Jun 10, 2004.
  1. diabolik
    diabolik
    How does the lip sync on the iscan HD work?
    Does it introduce a constant time delay between the video and audio streams for a particular input ir is is somehow dynamic? The reason I ask is that my NTL box has lip sync issues with some broadcasts but not with most. If the broadcast is at fault then how on eath does the iscan cope with this?
    :confused:
  2. jmack
    jmack
    yes it syncs the sound and pictures together, great piece of kit,
    you will need to convert it to digital first though. i think maplins sell little boxes for this.
    the is an added feature were you can add more delay, but i never use it
  3. diabolik
    diabolik
    Thanks for that, I know it works but how??????
  4. DDRUK_Lawrence
    DDRUK_Lawrence
    Apr 29, 2004
    37
    From the manual : "iScan HD automatically delays the input audio to match the video processing delay. You can choose to increase or decrease the audio delay by changing this setting."
    The iScan delays the audio based on the video processing applied to the input signal. It doesn't automatically correct signals that are input already out of sync (such as sky). You can increase or decrease the automatic setting manually for each input signal (eg. you can set it to +3 for input 1 receiving Sky and to +0 for input 2 receiving DVD).
    I tend to adjust it sometimes when watching Sky but never need to touch it for DVD's
  5. diabolik
    diabolik
    ok, thats clear. Thanks very much. :smashin:
    Have you noticed any reduction in sound quality through the iscan?
  6. DDRUK_Lawrence
    DDRUK_Lawrence
    Apr 29, 2004
    37
    None at all. It's all digital input and output so I wouldn't expect any either ;)
  7. Jasonjo
    Jasonjo
    Dec 3, 2001
    2,677
    UK
    +115
    diabolik,
    check out my HD review thread for a link to the keene A/D converter I use to feed the iscan from NTL.
    JJ
