iScan HD discrete remote codes
D
Deaky
Has anybody had any luck using these? I've spoken to dvdo and they say that sometimes the IR engine locks up and refuses the discrete codes. The only way to get them working again is to do a factory reset. After this they work fine but as soon as you use the ordinary remote to get the settings back, the discrete codes stop working.
I have the latest firmware and I have tried the firmware which is listed as being compatable with the discrete codes. Both are the same.
DVDO said the problem may be fixed in a future firmware release but seeing as there has not been a release for 12 months and the HD unit is now discontinued I think that may be unlikely.
Does anybody know if the discrete codes work on the HD+ without any problems?
