Iscan HD connection advice
Discussion in 'Projectors, Screens & Video Processors' started by HeweyBoy101, Oct 26, 2004.
  1. HeweyBoy101
    HeweyBoy101
    Jul 9, 2004
    878
    Lancing, West Sussex
    +71
    Have ordered iscan HD, but a little unsure what cables I may require to get the best quality signal input. Will initially use Component for DVD, and S-Video for Sky+. As regards Sky+, what would I need to get RGB from scart output on Sky box, into the iscan?
    I understand that the iscan will accept RGB input via the component jacks, but don't understand the implications as regards correct sync connection etc? I understand that this route may be better than straight RGB to component conversion?
    Any advice greatfully received. Thanks.
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    need a scart to 4 RCA cable RGB and composite for Sync..... What you connecting the Iscan too?
  3. HeweyBoy101
    HeweyBoy101
    Jul 9, 2004
    878
    +71
    Will be connecting iscan to my 37" Philips PF9965, via analogue VGA connection.
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    i think that is an ALIS panel so choosing the resoluion will be tricky but you should see some big improvements.... I reconmend a home demo first tho.
  5. HeweyBoy101
    HeweyBoy101
    Jul 9, 2004
    878
    +71
    Thanks - I will be collecting iscan from dealer tomorrow - I have it on trial until Monday. Hoping for big improvement. Yes, it is an Alis panel, so I will initially try 1024 by 1024 or maybe 1024 by 512. Will look to upgrade panel in due course, but see iscan as being fairly future proof, so hopefully a worthwhile purchase.
