I have a V7 Panasonic 50PHD7 plasma and have just ordered an iScan HD+ and am looking forward to having a play.
I have the 2-slot 42TM6Y (Component/RGB/SVideo/Composite) board and the usual VGA connector and wondered what was the best analogue connection to use.
I am waiting for an updated HDMI/DVI board from Panasonic that supports 50Hz which I'm sure will arrive eventually. So for now it's analog for me.
If I go VGA-VGA I may have to use RGBHV which limits me to interlaced. Is that correct?
I think there are problems with Component through VGA on these panels. Is that correct?
Otherwise I can go VGA-Component through the 42TM6Y. Is that a good choice?
Anyone using a HD+ on this screen and care to give me some clues as to how it should be set up
thanks
Clliff
thanks
Clliff
