Iscan HD+ and 43MXE
Discussion in 'Projectors, Screens & Video Processors' started by imclueless, Mar 2, 2005.
  1. imclueless
    imclueless
    Well the plasma arrived 4 weeks after my Iscan.
    I plugged the Iscan to Pioneer using a DVI cable set output to DVIP (and DVIV) output format to XGA and ............ nothing.
    Screen works with svideo ouput and analog dsub.
    Is it a faultly cable (from sony computer to sony lcd screen) or something even simpler
  2. loonatic
    loonatic
    Jan 4, 2003
    1,925
    41
    Springwell Village, Gateshead
    +16
    Do you know if the HD+ requires the display to be HDCP compliant even if your not using a HDCP source...I guess what I'm asking is does the HD+ output HDCP encrypted signals via DVI regardless of the input or only when it detects a HDCP source ?
    Cheers, Lee
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
  4. imclueless
    imclueless
    My fault trying to catch two audiences!
