Iscan Connection Help
Discussion in 'Projectors, Screens & Video Processors' started by fatrich, Jun 27, 2001.
  1. fatrich
    fatrich
    Jun 21, 2001
    2,617
    71
    halifax
    +53
    thankyou to Alan for his advise and quick response
  2. fatrich
    fatrich
    Jun 21, 2001
    2,617
    71
    halifax
    +53
    today i'm buying the iscan but am a little unsure where to connect every thing if i run through how i think it should be connected can you experts out there correct me if i've done it right or wrong:
    starting with the dvd player: (pioneer 737) component out to iscan component in, ( set to output component from the dvd not progressive component)
    On-digital box: scart output to rgb-s-video converter,s-video lead from the converter to the s-video input on the iscan.
    Output from iscan via the 15 pin vga type connection to the projector (PLV-30 Sanyo)
    now this is where i'm not so sure is it best to go in to the component input side of the sanyo or via the computor 15 pin vga connection.i will need either a vga to vga lead or vga to component lead can any one tell me where is the best place to purchase one of these and which gives the best results.
    many mant thanks
    fat rich
    null
  3. Alan Roser
    Alan Roser
    From our tests, the best performance is given by using the Progressive Component input on the Sanyo PLV30 with the iScan.
    Regards
    Alan Roser
    Owl Video systems
