Isacn
Discussion in 'Projectors, Screens & Video Processors' started by petrolhead, Dec 20, 2004.
  1. petrolhead
    petrolhead
    Mar 29, 2002
    4,783
    87
    Newcastle
    +116
    I discussed the merits of the Iscan HD a while ago with member including Liam
    My situaltion is that I have a Pace Freeviw Box (old OnDigital) and a DVD with component out and I know I can improve the signal to my TW100 PJ by using upscalling and the DVI out.
    Now the HD+ is out with HDMI and encoding. I will probable, in the future upgrade my HK DV25 to something with HDMI out and as the TW100 can't handle the encosing will use the HD+ to do that or am I wrong?
    Will I notice a dference between componet in from my HD against HDMI from a HDMI player?
  2. petrolhead
    petrolhead
    Mar 29, 2002
    4,783
    87
    Newcastle
    +116
    Having spoke to Joe (Cheers) I have some clarity
    I was hoping that the HD+ would get rid of the encoding but it doesn't :(
    But If I upgrade to an HDMI enables PJ then the HD+ will upscale the image whereas the HD will not (pass thro only).
    He has also suggested the LumagenDVI as being a cheaper alternative as, due to having the Tag, I do not need to delay processsing og the Iscan
    Any thoughts on the above?
