Is Xbox Live down?
Discussion in 'Xbox Forums' started by Bonesy, Nov 21, 2004.
  1. Bonesy
    Bonesy
    Feb 22, 2002
    1,149
    Wiltshire
    +28
    Doesn't say so on the website, but my xbox cannot connect for the last few days, says xbox live unavailable.
    xbox seems to know there's an update needed.
    but the last connection test out of the four fails..
    damn.
  2. kirk grubb
    kirk grubb
    Sep 6, 2001
    566
    +9
    Just finished a session of halo 2, with no connection problems.
    Anyone up for skirmish 2moro?
    Gamertag- grubby1
  3. CAS FAN
    CAS FAN
    Nov 24, 2003
    34,814
    167
    The Wheldon Road end!
    +7,971
    Nope, my works fine. You could have had your box banned - check out xbox scene for more info.
  4. Bonesy
    Bonesy
    Feb 22, 2002
    1,149
    Wiltshire
    +28
    No, my highly reliable and technologically advanced Linksys modem/router needed rebooting for some reason, even though surfing still worked.
    thanks for the replies.
  5. Malone
    Malone
    Mar 12, 2001
    1,857
    Ilkeston,Derby
    +71
    Wish I'd seen your post bonesy mine had EXACTLY the same prob last week until Colesy advised rebooting all equipment, Linksys wireless Router(BEFSW11S4) and Linksys ethernet bridge (WET11) It turned out to be WET11.
    Matt
  6. derekrcross
    derekrcross
    Feb 20, 2001
    442
    19
    i had the same problem last week and i have a d-link router :thumbsdow
  7. Bonesy
    Bonesy
    Feb 22, 2002
    1,149
    Wiltshire
    +28
    Matt, tell me about it. Not been on Live all week thinking it was having an update, not have to remember to give the thing a boot once in a while. Still, work are giving me a netgear to use, so will swap out.
  8. captaineyecatch
    captaineyecatch
    Feb 9, 2002
    2,013
    38
    South of Heaven
    +21
    Oh no not the dreaded netgear - another router that has problems with people not hearing you or you not hearing them - make sure you set up the ports correctly and hopefully it will work fine.
