Is xbox composite, s-video or something else?
Discussion in 'AV Receivers & Amplifiers' started by pipedream72, Jan 26, 2005.
  1. pipedream72
    pipedream72
    Hi, I'm new to all this so please bear with me. I've just bought a Yamaha r-xv650 so that I can get surround sound for DVD's and gaming. I use my XBox for both.
    My xbox is currently connected to an RGB Scart input on my TV using the standard AV cable. I think I'm right in saying that this cable incorporates audio (L + R) and composite video. So question 1 is:
    Q1 - Can an RGB scart input somehow handle audio and also a composite video signal?
    An alternative to the AV cable is the 'Advanced scart cable'. The xbox website describes this as 'connects the console to TVs equipped with a SCART input terminal and enables RGB video signals for improved video output'. For some reason I thought that this cable supported S-video, but either way my second and third questions are;
    Q2 - How can the same output on the XBOX support different video signals? Does it detect the advanced cable and switch the video?
    Q3 - If I get the advanced AV cable so that I can get the digital sound, what is the output video signal and which video in should I be connecting to on my amp?
    To add to my confusion, the xbox hookup guide on the Monster Cables site, shows that you can have composite (I think?), S-video or COmponent video out of an xbox. This leads to my next question:
    Q4 - Since I don't have component inputs on my TV, am I right in thinking that there is no point in using component between the xbox and the amp?
    Finally, the manual for my amp suggests that I use the VIDEO AUX terminals on the front for my xbox. I don't really want to have cables hanging out so:
    Q5 - Can just use one of the other sets of inputs on the rear to connect the xbox? Perhaps the DVD ones since I don't have a dedicated DVD player?
    Thanks a lot for any advice. I'm slowly getting there trawling through all the excellent advice on the forum. :thumbsup:
    Cheers,
    Steve.
  2. John
    John
    Dec 13, 2002
    11,198
    +2,832
    Right , after that massive post :D , simple answer
    As your TV does not have component in , Official MS Advanced Scart pack is the way to go.
    This will give you the best picture , and also toslink optical out to give you DD :smashin:
    Bet you wish you had posted ;
    "I don't have "component in" .Whats the best way to connect my XBOX"
    Have Fun
    John
  3. pipedream72
    pipedream72
    Hi, thanks for the info. Trouble is that when I get into some thing new like AV stuff, I tend to get a bit anal about wanting to know how everything works so that I understand why one setup is better than another.
    I think I've answered Q5 in my original post as the manual for my amp seems to suggest you can re-assign the inputs so I can just change the default VCR 2 input to be my XBOX input.
    If anyone could have a bash at answering my other 4 questions just so that I can extend my own understanding (and maybe even help out someone else in the future) that would be great.
    Cheers,
    Steve.
  4. John
    John
    Dec 13, 2002
    11,198
    +2,832
    Hi again , you would probably have got more response posting in the Console Forum :D .
    But as I'm here and Beer free :clown: tonight , I'll try to answer a bit more in depth
    Input on the Telly ? Yes , I would have thought so .Try connecting a VCR by scart , they only output composite (unless it an Svhs deck)
    Don't know how it does it .But the answer is yes , it does auto detect the cable used
    Depends what cable you buy .You can get Svideo (i think) ,RGB Scart and Component . You have said your tv does not have Component in .So I would suggest getting the Advanced Scart Pack , plug that straight to the TV and only the optical into the amp
    Yep :smashin:
    Easier to answer if I/we knew what the rest of your kit was . But there is no reason why you can't plug it into another scart socket. Do you have another RGB one ?
    All the best
    John
  5. pipedream72
    pipedream72
    Hi John, thanks for the info, that makes more sense now. Got to say that I'm surprised that an XBOX can handle multiple types of video signal including composite, RGB, s-video and component....
    I've read a bunch of other threads about amps being able to output an RGB signal when they only have composite, s-video and component outs like mine does. Apparently some can support this via the component outs. I think I need to find out if I can get RGB coming out of my yamaha 650 and that will dictate whether I use the RGB in or the s-video in on my tele (I believe RGB is better than s-video?).
    Thanks again,
    Steve.
  6. John
    John
    Dec 13, 2002
    11,198
    +2,832
    The RGB they upconvert to is Component RGB .Its a different standard to Scart RGB and as a result ,not interchangeable . :lesson:
    Your TV does not have component in , so your amp will not output a compatible signal .Stick with the MS Scart pack , you won't go far wrong :smashin:
    John
  7. John
    John
    Dec 13, 2002
    11,198
    +2,832
    Have a read of this
    It will open your eyes a little wider :thumbsup:
    John
  8. pipedream72
    pipedream72
    Hi John, very interesting and has certainly helped to educate me a bit more. Thanks again for all the info. Off to buy my MS Scart pack tomorrow!
    Cheers :smashin:
    Steve
