Is X-Box 360 a DVD player?
Discussion in 'Xbox Forums' started by Bristol Pete, Jun 29, 2005.
  1. Bristol Pete
    Bristol Pete
    Oct 18, 2002
    5,577
    Bristol.
    +321
    I have not had time to read up on the 360, but I was wondering if it will be a DVD player from scratch, aside from an add on dongle? :confused:
    Thanks,
    Pete. :smashin:
  2. Pooon
    Pooon
    Dec 26, 2002
    7,126
    Canterbury, Kent
    +731
    Yes it plays dvd's from scratch, the dongle you mention is more of a multimedia remote that looks like this:
    [​IMG]
  3. Bristol Pete
    Bristol Pete
    Oct 18, 2002
    5,577
    Bristol.
    +321
    Thanks for the quick reply. Was going to buy a new cheap DVD deck but will wait and use this as my all in one machine.
    One more question, any ideas if it will be backwards compatible with my Lik Sang sourced MS high def kit?
    Thanks,
    Pete.
  4. Pooon
    Pooon
    Dec 26, 2002
    7,126
    Canterbury, Kent
    +731
    Not sure. But not really an issue as it come with this in the box as well:
    [​IMG]
  5. Bristol Pete
    Bristol Pete
    Oct 18, 2002
    5,577
    Bristol.
    +321
    Excellent. MS really are covering all bases then.
    Thanks for your efforts.
    Pete.
