Is vga to dvi possible?
Discussion in 'Cables & Switches' started by Gadget Daddy, May 3, 2005.
  1. Gadget Daddy
    Gadget Daddy
    Feb 19, 2005
    3,281
    83
    Stockton on Tees
    +185
    In my system all my inputs go to a zinwell scaler, which has an output of either vga -> vga or vga -> component, Im not that impressed with either so far, so in my quest for best pic possible I was wondering if vga -> dvi is possiible, and if i is m is it best to go for adaptor or cable.
    Pete
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    23,759
    The Borders
    +2,463
    PeteB 2000
    If your not impressed so far there's very little a conversion from Analogue to Digital via a DVI adapter is going to add to the party; and its quite an expensive conversion (around £220.00) to find it adds nothing to your system.
    I'd suggest you look closer at the Video Processor and maybe Trial an alternative to see if you can achieve what your after.
    Best regards
    Joe
    Remember - 'Garbage In > Garbage Out'.
  3. Gadget Daddy
    Gadget Daddy
    Feb 19, 2005
    3,281
    83
    Stockton on Tees
    +185
    Thanks Joe
    Pete
