crazyfool92
I've got a 2017 Shield connected to my Denon 1300, so that I can can get losses audio to my 5.1 system. I mostly stream 1080p remuxes from my plex server. I have have just recently bought a LG C1 65", I've also had a Nvidia Shield Pro 2019 delivered this morning that I got for £161 from Curry's Ebay. I only bought this so that I could get Dolby Vision playback for UHD remuxes. But after a bit of research the shield only seems to play MEL and not FEL DV and it's not capable of playing the YouTube HDR codec (this doesn't bother me as much as I can use the LG YT app).
Is the difference in HDR10 vs DV worth the £161, I don't even get the advantage of having the new remote as I bought one separately for my 2017.
Basically, do you think I should return the unopened 2019 Pro and stick with the 2017 for the time being?
