I have a friend like you!Originally posted by Stephen Wilde
I prefer my Fuji. What does StooMonster think of them?
Originally posted by airdrawn
thanks for that. just a couple of small things. what do you mean by the hitachi panel is not a prog screen? does this mean that my harmon dvd 25 will only be able to output interlaced?
I have seen the panny in action and was very impressed with how three dimensional it looked. only chance i can get to see an hitachi is the pd3000 at currys, which is very poorly set up. looked ok with monsters inc, but then so do all plasma! have you ever compared your 400 with a panny 6 like for like?
thanks
Originally posted by MAW
Though I agree with all you say about the PMA400, fine screen for the money, a serious contender, is there not an issue with pal progressive support with the PMA? I have heard it needs a software update. I speak only of hearsay on the forum, never tried to put prog. scan into one, as even Hitachi themselves recommend RGB and sync as the best connection method.
Originally posted by Deron
Isn't the pma 500 supposed to be brighter and blacker though...?
Harvey, you are such an innocent, no offence meant. The manual may say one thing, but try telling the screen that. The pma400 won't be the 1st or the last, and very far from the worst, offender in that respect.
Originally posted by MR2Harvey
Brighter yes 1100 instead of 1000
Blacker no Both 1000:1
Mind you for £200 more and better connections I'd get that screen now, although very pleased witht he 400E.
