Is Tom Tom Mobile as good as a stand alone unit?
Discussion in 'ICE, Sat Navs & Dash Cams Forum' started by ToshTV, Mar 17, 2006.
  1. ToshTV
    ToshTV
    Hi guys
    I will shortly be buying a sat nav system.
    I have a Nokia N70 and am considering getting Tom Tom Mobile 5 for it, but I have noticed you can buy standalone sat nac units for around the same price - £200.
    I am really keen on having sat nav on my mobile, but will a stand alone unit for the same price be a lot better?
    Many thanks
  2. Dubster
    Dubster
    Mar 14, 2004
    1,167
    Down South
    +119
    The N70 are notoriously problematic with tomtom mobile (search pocketgpsworld.com forum and many others) so if you want something that works go for a standalone or if you still want a satnav phone get a 6680 or 6630 which by all accounts works really well with tomtom mobile.
  3. Koptalk
    Koptalk
    Mar 16, 2006
    14
    4
    I've got the NOKIA 6680 and loaded it up with TOM TOM sat nav.
    Got TOM TOM 256 memory card off Ebay for £20
    Bought TOM TOM gps receiver from Ebay for £60
    All loaded up with points of interest aswell.
    ASDA.PETROL,CASHPOINTS,McDONALDS,PREMIER LODGE etc.
    Absolutely fantastic!
    Highly Recommend..:clap:
  4. Joed
    Joed
    Mar 20, 2006
    69
    I've been using nOKIA 6680 without any problems. Using a Holux bluetooth gps reciever.
  5. ToshTV
    ToshTV
    Thanks guys. I will look into the problems with the N70.
    Looking forward to getting the sat nav though!
  6. RSRAVI
    RSRAVI
    Dec 15, 2003
    3,735
    71
    LONDON
    +87
    ToshTV
    There are no problems with tom tom moble 5.20 and nokia N70
    as long as you have the latest Firmware on the N70 as older versions
    have blue tooth problems ......
    my one is running perfect no problems .......:smashin:
