Is threre a decent DVD/CD-RW combo drive out there?
Discussion in 'Desktop & Laptop Computers Forum' started by Desmo, Jun 6, 2002.
  1. Desmo
    Desmo
    Jan 4, 2001
    14,296
    Braintree, Essex.
    +6,033
    Normal HTPC rules apply. Must be quiet in DVD mode. Noise not important when writing CD's. Region free firmware available, etc, etc.
    Slot or Tray loading is fine and preferably not over expensive.
    It's to go into the DIGN HTPC case so I've got a one stop shop for playing mp3 playlists and burning available from the one machine, along with the DVD playback as well, obviously.
    God that took a long time to type with one hand. Broke my collarbone at Donington last Friday :(
  2. nutcase_1uk
    nutcase_1uk
    Apr 15, 2002
    479
    Essex, unfortunately
    +3
    lo again des :)
    I think I saw that plextor are relaesing a combo drive soon (IDE :() so maybe it might be worth checking that out.
  3. Desmo
    Desmo
    Jan 4, 2001
    14,296
    Braintree, Essex.
    +6,033
    lo nut. I won't be getting it for a while. Just wondered if anyone had experience of one, how noisy they are compared to dedicated DVD drives. I wouldn't have thought they'd be much different.
  4. nutcase_1uk
    nutcase_1uk
    Apr 15, 2002
    479
    +3
    Well, I've never owned a burner, yet alone a combo, so I'm not an 'authority' I' afraid. Plextor should be darn good quality though :)
  5. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    My laptop has a dvd/cdrw combo drive, it's not noticeably noisier than my HCPC DVD drive, we use it on the boat for the odd movie when the weather is crap, like a lot recently! Background noise is not intrusive even when it's on your lap! It's labelled Mat****a, obviously it wouldn't fit a desktop case, but I mention it cos I can't see why a desktop drive should be so different, though the CDRW on my cinema pc can buzz a bit when forced to work hard, I think maybe it's a bit old.
    Martin
    Honest thats what the drive is called, I see it's got asterisked!!! The case is a kind of dark brown mind you.
