is this worth the money ?
Discussion in 'Cables & Switches' started by nicke20, Dec 26, 2004.
  1. nicke20
    nicke20
    Oct 11, 2003
    885
    +13
    lurking on ebay their is a company that sells lots of av cables, I am soo to get my plasma and will require some component cables. they sell at an avaerage price of £40 ixosxhv804 cables, any good ? or should i spend a bit nore and get marks special offer stuff?
  2. nwgarratt
    nwgarratt
    May 5, 2002
    27,189
    +3,038
    Is teh seller "Fill your boots". I was looking at bidding on the same cable from them. However, they end up around £40 and not far of their buy it now price. They retail at around £70 from most AV shops/sites.
    I ended up using Blue Jeans Cable as they do the same cables as Mark. They are a ebay seller as well. However, I got a customs charge on a £21 four foot component cable. It ended up at £28.
  3. nicke20
    nicke20
    Oct 11, 2003
    885
    +13
    yes it is "fill your boots" the feedback looks ok. I have never gone down the route of named cables but as they will be in a conduit in a wall i think id better put good ones in.
  4. PannyAdams
    PannyAdams
    Dec 5, 2004
    669
    Epsom
    +5
    I was going to bid on this auction.....maybe we should make a deal to stop bidding the price up for each other!
  5. nicke20
    nicke20
    Oct 11, 2003
    885
    +13
    I never bid the price up, only fools bid early.
    i set my max price, put it into my sniping programme and set it to 10 seconds before the end of the auction.
    The only time you will see a bid from me is if it is a winning bid
    :laugh:
