Is this worth it - PDP-4330HD for £1499
Discussion in 'TVs' started by nicp01, Mar 3, 2005.
  1. nicp01
    nicp01
    Nov 25, 2004
    148
    +3
    www.korounos.com are selling the PDP-4330HD for £1499 is this a good deal?
    peter
    Ive edited it...sorry should have been korounos
  2. Taz69
    Taz69
    Apr 15, 2002
    2,355
    Bristol
    +54
    No site listed, you sure its the right spelling m8
    Taz
  3. rigman
    rigman
    Dec 14, 2000
    2,760
    83
    East Yorkshire
    +59
    Looks like a good deal to me as Pioneer are very highly regarded. Does anyone know if this is suitable for Sky HiDef?
  4. Dog with 3 legs
    Dog with 3 legs
    I think the earliest Pioner suitable for HD (vie Sky that is) was the 434
  5. Taz69
    Taz69
    Apr 15, 2002
    2,355
    Bristol
    +54
    Details taken from another site, not sure if the media box which according to the site makes it Hi-Def, looks like it only has Component inputs not DVI/HDMI, either way if the company checks out etc, its got to be a better bargain than the Pannys/LG's etc out there at the mo, with the res, its fit for Euro1080 etc.
    Key Features:
    * Plasma panel: HDTV monitor (compatible with HDTV/SDTV formats — when connected to a separate HDTV tuner — and displays them at 768p)
    * 43" plasma panel (measured diagonally)
    * widescreen 16:9 aspect ratio
    * 1024 x 768 pixels (Think this should be 1280x768 for Sky Hi-def)
    * progressive display (all pixels display at once)
    * 160° x 160° viewing angle
    * Deep Encased Cell Structure for improved brightness and accuracy
    * High Contrast Black Stripe Coating
    * detachable stereo speakers
    * detachable stand (depth is 13-1/8")
    * 42-1/16"W x 24-3/4"H x 3-7/8"D (30-5/16"H x 13-1/8"D with stand)
    * 48-1/16"W x 24-3/4"H x 4"D (with speakers)
    * weight: 69.4 lbs.
    * warranty: 1 year parts & labor
    * Media Receiver: dual 181-channel NTSC tuners
    * 2-tuner picture-and-picture (split-screen)
    * Automatic Format Conversion (upconverts NTSC signals to progressive)
    * PureCinema II 3-2 pulldown processing
    * MTS stereo reception
    * 12 watts x 2
    * SRS Focus™ virtual surround for enhanced 2-speaker sound
    * illuminated multibrand learning remote
    * 5 A/V inputs, including:
    o 4 composite video (3 rear, 1 front)
    o 4 S-video (3 rear, 1 front)
    o 2 rear-panel wide-bandwidth component video
    (compatible with 1080i/720p/480p/480i signals)
    o 1 rear-panel RGB input for HDTV (D-Sub 15-pin)
    o 1 front-panel RGB input for PC/Mac (D-Sub 15-pin)
    * 1 A/V output (composite video and S-video)
    * 2 RF inputs for antenna/cable
    * stereo mini headphone jack
    * 16-1/2"W x 2-13/16"H x 15-1/4"D
    Taz
