Is this what I think it is ?
Discussion in 'General TV Discussions Forum' started by paulfoley, Apr 24, 2005.
  1. paulfoley
    paulfoley
    Sep 17, 2003
    3,570
    Hants
    +119
    Is this what I think it is i.e. a box that takes your High Def, HDCP encrypted picture & converts it to an unprotected VGA signal. If it is then it may be the simple answer to all those frustrated early adopters of LCD TV's & high def plasmas ?
    Link
    :thumbsup:
  2. Dutch
    Dutch
    Dec 5, 2002
    2,601
    2
    5
    North Yorkshire
    +284
    Err, yes it is. ;)
    Steve
  3. paulfoley
    paulfoley
    Sep 17, 2003
    3,570
    Hants
    +119
    I'm starting to doubt it now. The example picture shows only a PC. Now am I right in saying that a PC's DVI Graphics card can ouput both digital & analogue signals? Perhaps the box will only tap into the HDCP signal if the source has analogue as well i.e. it wont work with a High Def Sat Box ?
    :confused:
  4. AML
    AML
    Jul 22, 2004
    4,989
    Tokyo
    +228
    It says DVi-D which is digital only. Have a close look at the link and the specs of this adapter. Its ideal for those who dont have an HDCP TV!
    Still, you wont get the proper resolution right? Not if using analog RGB?
  5. mi_july
    mi_july
    Wouldn't you? I mean surely the resolution wouldnt change?
  6. Flimber
    Flimber
    Sep 22, 2002
    13,681
    Yorkshire
    +4,477
    This box of wonder has been discussed on here before. See previous thread(s).
    Mike.
  7. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,176
    Norwich
    +796
    The box simply transcodes dvi to rgbhv, and you can not get hdcp on rgbhv so yes it does what you think it does, and is being used by loads of crt owners in the states.
    There will be hundreds of variations on this when really needed.
  8. Litch
    Litch
    Dec 20, 2004
    84
    +10
    My Sony Plasma is capable of receiving HD, but only via component (3xRCA).
    I guess I would need to get and vga to component converter too. Wonder what that will do to the PQ :( DVI-I > vga > vga > component is this even possible?
    As you say, maybe when the demand is there, there will be lots of little black boxes. As I'm not in a hurry to buy a new display.
  9. laser
    laser
    Aug 1, 2004
    987
    Hartlepool
    +46
    Would anyone know if a HDMI to DVI converter cable would work with this box?
  10. Dutch
    Dutch
    Dec 5, 2002
    2,601
    2
    5
    North Yorkshire
    +284
    I don't see why it shouldn't - that's what I'll be using when the time comes.
    Steve
