Question Is this the right connections needed for a new gpu
JamesLFC2018
Hi guys, am I right in thinking these two are 4 pin molex connectors and I can plug this adapter into these to power the new gpu I'm getting which is 8 pin.
dollag
dont you have 8 pin pci from your psu?
JamesLFC2018
hi @dollag thanks for replying :D
I have a EVGA B3 850W 80 rated Bronze PSU? that has 3 available slots that says VGA 1, VGA 2, VGA 3 if that helps at all?
Am i right in thinking that this cable will do the job 8 pin to dual 6+2 pin connectors
8 pin end would go into the VGA 1 port on my PSU and the other end (6+2) would go into the Graphics Card? with the other 6+2 connector available if i ever needed to use a gpu that required two 8 pins?
dollag
yes that's correct :smashin:
