Is this the best way?
barneybelly
Hi folks,
Just got myself a new tv and have set it up with my other equipment. I have set it up like this,
LCD TV to Panasonic dvd recorder via component cables
LCD tV (rgb scart) to tv scart on sky box
Panasonic dvd recorder (AV2 scart) to vcr scart on sky box
Is this the best way as i have AV1 on dvd and AV1 on tv empty (should they be used in any way?)
Also the rf aerial is going straight from source direct into tv...again is this the best place for it?
And finally...what kind of settings am i looking at putting the tv, sky box, dvd on if i have them setup like above?
Sorry for sounding like a novice but i am and i just want the best way possible!!
:smashin:
Ian J
I would say that the cabling is correct as it is making use of the best possible picture opportunities.
I don't understand your questions about the settings though :confused:
barneybelly
Thanks Ianj,
Sorry...i meant the settings on each of the dvd, tv etc when you go into the menus and change the internal settings to correspond with the connection you have set up.
sbowler
Make sure the outputs are all RGB enabled int the menus of both the VCR and SKY. ensure that you are using the RGB scart on the TV, only one scart on my TV will accept RGB. I would then use one of the THX Optimode DVDs theres one on Terminator 2 and also Fight club and one of the Toy Story discs amongs others. The tests containded within will help you set up the correct levels and geometry of the picture.
