Is this spec ok for HD / Blu Ray ?
Discussion in 'Desktop & Laptop Computers Forum' started by northender, Jan 16, 2008.
  1. northender
    northender
    Apr 28, 2006
    7
    I have started to build my HTPC and before buying the real hardware ( mobo etc ) I would like to see if anybody has any comments about the parts. All the parts are build around my budget. I want to use this for playing HD movies and tv series, both from dvd's aswell as from files on the hhd. Thinking of ripping the dvds to the harddrives to save loading the discs. Any thoughts on this, not the best way to playback ?
    Power Supply 520W Coolermaster Real Power M520 Modular PSU 2xPCI-E >80% Efficiency
    Case SilverStone SST-LC17B (Black) aluminium Front & SECC Body Desktop case (w/o PSU)
    HDD 500 GB Samsung HD501LJ Spinpoint T166, SATA II, 7200 rpm, 16MB Cache, 8.9 ms, NCQ
    HDD 80 Gb HGST (IBM/Hitachi) 0Y30005 Deskstar 7K80, SATA300, 7200 rpm, 8MB Cache, 8.5 ms, NCQ
    DVD Drive Samsung SH-S203N/RSMN 20xDVD±R, 12xDVD±DL, DVD+RW x8/-RWx6, SATA,Lightscribe, Black, Retail inc Nero
    BR Drive LG GGC-H20L Lightscribe SATA 16xDVD±R, +RWx8/-RW x6 Also READS Blu-Ray/HD Discs black OEM (Inc Soft)
    Card reader SilverStone FP34 3.5" Front Card Reader and I/O Panel
    Mobo Gigabyte GA-MA69GM-S2H AMD 690G, SAM2, PCI-E (x16), DDR2 533/667/800, SATA II, SATA RAID, uATX, VGA
    CPU AMD AM2 Athlon 64 4400+ Windsor Core, Dual Core 2.3GHz, 2x 512KB Cache, Energy Eff'' Retail
    Heatsink Zalman CNPS8000 Ultra Quiet Low Profile CPU Cooler - All CPU's
    Memory 2GB (2x1GB) Corsair TwinX XMS2, DDR2 PC2-6400 (800), 240 Pins, Non-ECC Unbuffered, CAS 5-5-5-12
    Graphic card 256MB Sapphire HD2400XT PCI-E(x16) 64Bit 1400MHz GDDR3 GPU 700MHz CrossFire D-Sub/DVI/HDTV Retail
    OS Microsoft Windows Vista Home Premium 64Bit 1Pk OEM (DVD)
    Any comments appreciated. Although I have looked at other posts, I feel a little unsue this is upto the job.
  2. Walter Sobchak
    Walter Sobchak
    Mar 29, 2005
    1,034
    +37
    I would go for an Intel CPU and overclock it to save some cash.
  3. spongycortex
    spongycortex
    Definately go for an intel cpu.. Unless of course you already own some of the components.
