Is this speaker cable good? Profigold Air Bass Flex PGC81546 only £50 for 50m
Discussion in 'Cables & Switches' started by anit999999, Jan 20, 2008.
  1. anit999999
    anit999999
    Nov 15, 2006
    140
    London
    I can get a reel of 50m of Profigold Air Bass Flex PGC81546 bi-wire speaker cable for £50. Seems like a good price to me but is it any good? I have found a website which sells it for £7.10 per m. I found some specs below.
    Features:
    Profigold 4 core bi-wire silver plated oxygen free copper speaker cable featuring hybrid stranded conductors with solid core central conductor for improved bass response.
    Features 4 Core High Performance cable -ideal for Bi Wiring Speakers to transport the mid/high and low frequencies in separate pairs
    Solid Core conductor produces outstanding Bass response
    Silver Plated OFC Conductors deliver increased sense of clarity & tightest bass
    Additional Air Foam Insulation layer ensures transient response of high frequencies
    Silver plated stranded 99.96% Oxygen Free Copper conductors
    Solid 99.96% Oxygen Free Copper bass conductors
    4 way side-by-side, low profile design
    Specs:
    Overall conductors cross sectional area - 4 x 1.5mm²
    Stranded conductors - 168 x 0.10mm x 4
    Bass conductors - 1 x 0.50mm
    Outer jacket/insulation - PVC
  2. ben.bayliss
    ben.bayliss
    Feb 4, 2007
    1,198
    63
    +136
    For that sort of price, you really ought to be getting 2.5mm or even 4mm CSA cable. This is still only 1.5mm and so imnsho not worth it. Also, the whole part-stranded/part-solid core seems like a total gimmick to me.
  3. anit999999
    anit999999
    Nov 15, 2006
    140
    London
    But the cost actually only works out at £1 per meter.
  4. MarkTaylor
    MarkTaylor
    Feb 28, 2002
    4,328
    +662
    Do you actually need bi-wire cable or are you planning to make 2x3mm out of it instead of 4x1.5m?
    Even with 2x3mm it isn't cheap at £1 a meter compared to some alternatives, but if you are planning to bi-amp I'd look elsewhere as 1.5mm isn't really enough.
  5. ben.bayliss
    ben.bayliss
    Feb 4, 2007
    1,198
    63
    +136
