Is this right
Discussion in 'AV Receivers & Amplifiers' started by Mwillo, Aug 18, 2002.
  1. Mwillo
    Mwillo
    Feb 15, 2002
    139
    Liverpool
    I have just run the THX setup program on the phantom menace disk to check the setup on my Marantz 6200 , however when it comes to testing my rear centre the sound comes from my rear left/right channel. Have I done something wrong as i never seem to get a icon on the display to say i am using a rear centre.
    Thanx in advance for your help....
    mark:confused:
  2. Jase
    Jase
    Mar 16, 2001
    10,830
    United Kingdom
    +2,726
    It´s right, if you have no EX channel the sound will come out of the rear left & right channels instead. Your amp is´nt faulty!:)
