Is this product any good for cleaning the front of a Viera?
Discussion in 'Plasma TVs Forum' started by GalacticaActual, Dec 12, 2004.
  1. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,866
    Galactica C.I.C.
    +279
    I found this at work. Does any one know if they are any good for the front of a plasma screen? specificaly the plastic front of a Viera.
    Please click the images and have a look.
    Thanks in advance.Dave.
  2. blindlemon
    blindlemon
    It's gotta be better than this: [​IMG] :smashin: :D :D
  3. pjclark1
    pjclark1
    Jul 19, 2004
    4,463
    Thailand
    +271
    as the screen does not attract dust, I'm not sure what this cleaning obsession is all about. After 4 months my screen is still spotless.
  4. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,866
    Galactica C.I.C.
    +279
    Well you must have a very clean dust free house then :D
    The screen is not static free. after a day in use it was already collecting dust.
    I have been using a micro fiber cloth but al that does is move the dust around. A damp cloth leaves smear marks. Ekostar from these forums said that he/she uses something simualar to this. so the question still stands, is it ok for a plasma screen?. I know you have to be very carefull with what you use to avid damge to the antiglare coating and scratiching the plastic. What is recommened in the the manual just does not do the job.
  5. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,866
    Galactica C.I.C.
    +279
    That reminds me of the person who used bleach and a scrubing brush to clean her car :laugh: :laugh: :laugh:
  6. pantages
    pantages
    Jan 7, 2004
    945
    2
    Boston
    +60
    I just use a lint-free cloth and I never have static build up of dust.
  7. Ekko Star
    Ekko Star
    Mar 18, 2002
    6,618
    London
    +468
    Microfibre cloth & Screen Clene.
    My screen does not attract dust, even after months. There's dust everywhere else but not on the face of the screen.
    If your stuff is made to clean telephones with it's probably a general office use cleaner. Personally wouldnt use it. Get the recommended stuff above for about a fiver and it'll last you years.
  8. Pink Fairy
    Pink Fairy
    Dec 5, 2004
    239
    Watford
    +32
    Presumably you won't be going far wrong if you treat the screen as you would do an expensive camera lens or binoculars... or would I be presuming too much, in that the non-reflective coatings used on a domestic tv wouldn't be as durable and wouldn't appreciate a very mild alcohol based cleaner.
    From my experience with high-end optics, removing any foreign particles should be done with a blower before using a microfibre cloth.
    As a smoker, cleaning the screen will be an issue at some stage.
    cheers,
    Andy
