Is this possible?
Discussion in 'Desktop & Laptop Computers Forum' started by Iain Shields, Aug 20, 2003.
  1. Iain Shields
    Iain Shields
    Oct 19, 2001
    787
    N.Ireland
    +3
    Hi folks,
    This is possibly a stupid question, so please be gentle...
    I'm about to get BT broadband in and was wondering if this is possible:-
    Since my PC and XBox are in a room with no phone socket, can I use a regular phone extension lead (about 20 metres) directly from a phone socket into the room with the PC and XBox, attach a microfilter to that and then hook up a modem/router to the microfiter and hook up the PC and XBox to that? :zonked:
    I was going to go wireless but for everything it would probably cost around £200 or so, doing it the above way would cut this cost at least in half... I just don't know if it can be done :blush:
    Thanks in advance for any help.
    Regards,
    Iain.
  2. Sheks
    Sheks
    Jul 23, 2000
    524
    England, Surrey
    +24
    Hi, Iain
    I do just what you describe with a 10 metre extension cable from the telephone point, works fine with my bt broadband.
    Colin
  3. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    this is basically just what is done when adding new phone points..... it should work a charm as sheks says.
  4. Iain Shields
    Iain Shields
    Oct 19, 2001
    787
    N.Ireland
    +3
    Thankyou, just the answer I was looking for...
    Cheers.
    Regards,
    Iain
